- 20 Aug 2007
- Solihull
Watch said video, I've cleaned both lenses thoroughly with IPA, no change at all, any ideas? :O
Does it play games?
And does it literally not read them at all, or just not play them properly?
But isn't MW3 a blu ray disk so it does read blu ray then.
Is it just movies and all movies or burned private blu rays ?
in the video it is trying to read the MW3 Blu ray disc and failing to
same happened to mine, would read DVD's/CD's fine but it had loads of trouble with games and bluray movies.
They would either not appear on the XMB or if they did it would take for ever to load with the drive making noises as if it was reseting and starting again until.
Ordered a new laser unit for £30 in p&p from ebay and its worked perfect since.
Good thing with the slim ps3's they have a dual laser 1 for cd & dvd one for bluray - if it reads one and not the other you know its the laser. Just make sure you get the correct laser unit to match the one in the ps3.
Hooray! I got the laser direct, fitted it in, bit of guess work and perseverance!
