Probably a nooby HTMl/CSS question question, but still....
8 Oct 2005
Midlands, UK
Hi,
i have noticed on a few sites that upon clicking a link some text is revealed below e.g. some detail about a link. I'm not sure how this is done tbh. Also is the method (whatever it may be) web standards complaint, as i would like to implement this on a site that must work/look the same in the major browsers.
Thanks for any info.
After clicking the link? sounds odd. I believe you can apply alt text to links to describe what they do but that would just be when you hover over the link with the mouse.
The easiest way is to add the title attribute to the link. An example being:
Code:
<a href="your URL" title="your description">Link Text</a>
I'm not sure if you're after a more advanced tooltip, though. If you are then just google for it, there are plenty of tutorials for it.
If I'm thinking of the right thing, then it's usually done using javascript in some manner - an event handler is added to the bit you want 'clickable'. This in turn will toggle the display of the other element with the text in - either dynamically adding and removing it from the DOM, or toggling the CSS display/visibility property.
Yes, it is "web standards complaint".
Couple of examples (google something like "unobtrusive javascript expand collapse"):
http://www.onlinetools.org/tools/domcollapse/index.html
http://www.weberdev.com/get_example-4263.html
excellent link, exactly what i had in mind! esreality gave me the idea. E.g. click the "quake 4 attendies" link from this article
Yep, that link just changes the display property of a specific element from 'none' to 'block'. Not the cleanest implementation, but should work in the overriding majority of modern browsers :).
Markup:
Code:
<a onclick="flip('results1'); return false;" href="#">Quake 4 Attendees</a>
<div id="results1" style="display: none;"></div>
JS:
Code:
function flip(rid)
current = (document.getElementById(rid).style.display == 'none') ? 'block' : 'none';
document.getElementById(rid).style.display = current;
Pfft, sounded like tooltips to me! :p
I've used domCollapse on a little website in my sig - web design resources. It's very easy to implement, that's the one I'd go for.
