Probably been asked before - Volt Modding
4 Sep 2005
London
Hey all
I've got my X800XT-PE Running with a Zalman VF900. Stock clocks are 520/560 and i'm running it at 560/580.
I've heard that these cards can be volt modded, and i've been interested for quite some time now.
I cant clock the card much further than that before i get artificats. Temps are fine, they never go above 50c load. I was mainly wondering what methods are there to volt mod? I know theres the pencil mod, but it seems inaccurate to me.. and i cant risk frying my card.
So are there any easy ways of volt modding, and will it allow me to clock my card further?
Thanks for any tips :)
p.s On ati tray tools, how many artifacts are acceptable? It says there are artifacts when i clock too high.. but i cant see them..
if you cant afford to blow the card dont volt mod :P
yeah it will help you clock a bit further - you can use pots i think - ill have a dig about for the mods, you might wanna have a look at xs, im shure they will have it somewhere
i generally ignore what it tells, I stare hard at the area and if you see the slighest thing out of place before say a minute, then i clock back a bit (with atitool, not tray tools)
Volt modding usually involves soldering a variable resistor / potentiometer to trick the card into giving the core / memory more voltage.
I've done it with a few cards. The Powercolor X850XT responded very well.
If you do it, I would recommend just doing the core:
1) Because this is where most of the performance gains are.
2) Because I've had too many problems voltmodding the memory, which is easier to b0rk.
http://www.techpowerup.com/articles/overclocking/voltmods/112
and / or
http://www.techpowerup.com/articles/overclocking/voltmods/101
Depends what your card looks like.
