Homeserve came out Saturday.
Wanted to first take the meter out (they should unscrew), so he can inject gas into the pipe to find the leak, but it was in very tight and the pipework was wobbling - he didn't want to break anything. Seems a poor fit by Severn Trent.
Started digging a hole in the front garden where the pipe should run. Dug nearly a metre deep, he couldn't find it.
Started a second hole under the side entry path. Pipe found around 80cm deep. Difficult because of the other services in the space, including a very solid thick pipe/conduit of some sort covered in a black tar like material. Lead pipe is at the bottom of the hole on this pic.
He cut it, gassed the pipe. Got lucky (ish - see later) as he seemed to have landed on the leak. Pipe cut and a new piece inserted.
We monitored the meter for a while and it seemed to have stopped. He backfilled, re-instated the slabs and went away. All in, 8.30am till 3pm working on it.
Unfortunately Ive taken a reading today, and I think there is still a leak. I suspect his wrangling of the pipe to get the fittings on temporarily closed up the leak, and its reopened again.
Im taking readings now with house supply off, to see what the leak rate is.
