- 2 Jun 2003
- Bristol UK
I got myself a 360 Wireless Adapter today (for £35 might I add
) and I'm trying to create myself a Live account.
I'm doing on the 360 as i'm led to believe you get a months free Gold doing it this way. So I connect it up to my wireless router, put the WEP key in and test - everything A-ok. The 'NAT' says 'MODERATE' at this point. I try to create an account and after inputting the Windows Live ID credentials in after about a minute or so it says 'Xbox live signup is currently unavailable. Please try later'. Does that a few times.
I amend my router settings so that now the 360 is in a DMZ and when I test the 'NAT' says 'OPEN'. Result, so I try again and it stops at the same point
So do you reckon it's a problem with my adapter or Live account creation is fubar'd for the time being?
Cheers all!
Cheers all!
