Problem - Help.
16 Sep 2008
Southampton
Hopefully someone can help.
Basically my mouse pointer is stuck with the tea-timer next to it.
Really weird...started about 4 days ago. Can't seem to find out what is causing the tea-timer to continuously appear next to my mouse pointer.
Any ideas?
Thanks.
You think it's worth going into Task Manager and closing down processes until you see a change?
Just a thought.
Done that. Closed everything that was USER related...then closed a few others until the system had to restart. Still got the same problem.
