Problem in Gta:Sa
f22
f22
4 Jan 2005
I was playing san andreas for about an hour up to a few minutes ago, I had just saved the game when the screen went blue and all this text came up saying, something along the lines of some sort of error and the computer was going to be shut down to prevent damage! Thats about all the info i got before the computer restarted.
This is the second time this has happened, the other time was a few days ago, but only in san andreas no other game does this.
Anyone got any ideas why this is happening?
f22 said:
so is it any harm? or should i ignore it? why does it happen though?
I cant tell you how to reslove this, but if it happens a few more times, id put it down to your PC.
Maybe some drivers are out of date or something.
- Denic
hmmm.. thats a good theory denic, maybe it is his pcs fault that his pc isnt working properly?
yeah, id put it down to the pc as well.
Ah, might not just be a problem with nForce3 then. Are you using onboard sound with the nVidia drivers?
it was also an issue with a dodgy no CD crack, or any no CD crack for the game, which was annoying for a while as i only use my drive to install...
Another problem might be your paging file.
If you set that too high your hard drive (s) cant handle the speed of data and shut down, which shows the blue screen.
Probably drivers the only time i have had bsod with my pc is when i needed to update my ethernet drivers
