Problem installing CCC
8 Feb 2007
just got a second card 2day and am going crossfire, but when i put it in and turned on crossfire from ccc it BSODed so i re installed ccc but now it wont install properly, it comes on and says that the drivers where not installed and i many need to install them again.
i have tried again and again to uninstall and reinstall and have used driver cleaner as welll to remove but still cant get it to work. tried versions 7.6 7.7 and the beta's that are around (listed on forum)
and to top it off theres a damn thunder bug or whatever they are behind my monitor. better get its butt out or i will be fuming!!!
RavenUK said:
LOL, nice advice, now he cant even get a picture.. ;) :D
Woah! Thats not my fault, thats a basic thing to do, re-format if your stumped with a problem. Anyway, have you tried just using the new card without the older one. If that still gives off problems, then we know that the card is borked!
yeah i took out the old card leaving the new card in and then i formatted windows again
my vista score is 1.0 thanks to the graphics numbers lol
just installed CCC and now i am updating that score
might get some aero goodness? lol
and 800x600 looks really naff on a 24 " monitor lol
Ok, At least we know that your card is fine and its a driver realted issue or something you need to do. Your best bet now is to have a look on other forums to find the solution!
