Problem installing Rage from DVD
28 Dec 2007
Sheffield
Today I got Rage on DVD, however I'm having problems installing it.
I install it as normal and register the key to steam and what not, it goes through all the DVD's seemingly installing, but then after Disc 3, Steam says only 7% is installed and is currently downloading 20GB of data !!
Anyone know a fix?
I tried this but no luck :(
Thanks
THe solution in the sig is indeed the same one I posted, it just gives the same result after install.
And Steam doesn't allow you to install games in offline mode :(
