Problem overclocking my cpu
27 Aug 2006
Well i upgraded to a 4400 amd x2, and put it in my Asus M2N-E board, but its not like over overclocking boards, and im having trouble overclocking it, using a program called ai booster but when i increase the memory clock or set it to 105% i get a crash, or nothing, what am i doing wrong?
I would not use AI Booster personally. It caused me loads of problems. Better to do it manually as the previous poster said. Bear in mind you may not get a huge overclock on the 4400 if you are using stock cooling. I am sure you could hit 2.6GHz (equiv. 5000+) with a fair wind. I have so far managed 2.66GHz out of my 3800x2 though I had to overvolt fairly high to 1.58. May end up cutting it back to 2.6GHz @ 1.52V!!!. Impression I get from reading around is that 1.5V or under for Vcore (CPU voltage) is ok.
HTH
Jules
Overclock it manually. Read that guide and maybe use the information below.
Lets break this down a bit. Your CPU can be overclocked by increasing the FSB, and if this causes instability then you may be able to rectify that by increasing the CPU voltage. Your FSB can also be increased, and if this causes instability then you may be able to rectify this by increasing the chipset voltage. Also, your RAM can be overclocked by increasing the FSB, and if this causes instability then you may be able to rectify this by increasing the RAM voltage.
Can you spot the link in the above?
They all involve increasing the FSB, so how are you supposed to know what caused the instability?
Well, the simple answer is you can't. Unless you take measures to eliminate the other components from causing the instability. This is where the multipliers come in
Dividers are just ways of increasing/decreasing the speed of components relative to others, and independently of the FSB. If you decrease the CPU/FSB multiplier, you can eliminate this from being the component that is causing the instability. If you decrease the RAM/FSB multiplier, you can eliminate the RAM from being the component that is causing the instability. If it's still unstable after decreasing these multipliers, then it's likely that the mobo is causing the instability, and voltage can be added to the chipset to try to increase the overclock.
Try this:
1) Set your RAM/FSB multi to around half of what it should be (i.e. 1:2 ratio instead of 1:1);
2) Set your CPU/FSB multi to around half of what it should be (i.e. 6x, instead of the usual 12x - I think 12x is the multi ** CPU uses, but correct me if I'm wrong)
3) Try increasing your FSB in 5 or 10 Mhz increments and stability test between. If you experience instability, increase the chipset/NB voltage and try again. If it's stable, continue to increase the FSB. Keep doing this until you find a stable ceiling. Keep a log of all the FSB's and voltages and whether it was stable or not.
4) You now know what the max FSB is that your mobo can handle. Put the FSB back to stock, set the CPU multiplier back to 12x and start overclocking again. This time, keep your chipset/NB voltage inline with the notes you made for the frequency it's running at, and increase the CPU voltage if you get instability. Keep doing this, increasing in 5 or 10Mhz increments until you find the stable ceiling for the CPU. Keep a log!
5) Set the CPU multi back down to 6x. Set the RAM multi back to 1:1. Start increasing the FSB, chipset/NB voltages once again in line with the log you made, and increase in 5 or 10Mhz increments until you find the stable ceiling for the RAM.
6) You should now have the max stable overclocks for each individual component, so now you need to try to work all of them together by calculating the frequencies and dividers to try to get the best compromise for them all. Prioritise on the CPU speed first.
I hope that helps :)
