Hi guys and girls,
So the other day i installed a new graphics card (gtx 980 to replace my ancient 7970)
Basically, i used the 'AMD clean uninstall utility' to remove all my drivers for that card (not sure if maybe it removed other drivers too?)
Once the new card was in, i first booted up to just a black screen, all lights and fans were on as they usually would be and power was going to the monitor yet nothing else. so i took the card out, put it in a different pcie slot, and it now works however, the new problem i have is, pretty much every time i boot the machine up it'll go to a black screen and read,
"Reboot and select proper boot device or insert boot media in selected boot device and press a key"
anyone got an ideas as to what the problem is? once i manually turn it off as it has no option of shutting the pc down or doing anything for that matter is usually boots ok the second time.
Might be worth mentioning, before i done all this, when i boot my pc it used to come up with the ROG gaming screen where you can access the bios but now thats gone and i'm left with american megatrends? any ideas? i'll be honest i'm not great with computers so i have no idea what i've done.
motherboard is a ASUS Crosshair V Formula-Z ROG ATX by the way.
Thanks everyone.
Thanks everyone.
