Problem uploading files on FTP - 8-bit binary
2 Aug 2005
I have a few files which won't upload via my FTP, it says that the files are encoded in 8-bit binary. Is there anyway to fix this?
Thanks,
Thanks,
Transfer the files with binary mode, not (7 bit) ASCII which is normally the default. ("bin" command at the ftp prompt.)
Just changed it to binary but it's still not working. I'm using Filezilla, and there is ACSII Binary or auto transfer but even if I put it to binary it says critical transfer error. Maybe there's a better client I should be using?
It's weird though because I've uploaded files of the same extension before and it's not given me this error. :(
Try it from the command prompt in Windows:
ftp your.server.com
(enter user/pass as requested)
cd some_folder
binary
put thefile.bin
quit
