Problem with 3dmark11
17 Nov 2011
Birmingham
Hi, basically when I run the physics test im only getting 3 - 4fps nowadays which is really strange. I used to get 25 - 30fps and this is on my i7 3820 at 4.6ghz. So was wondering what could be causing this.
Yea i had that and weird scores when i first ran it but a bios reset and settings check sorted it.
I get 30fps in the 3d mark 11 physics test with rig in my sig.Physics score is around 9600.With use of HT you should be getting just over 10,000.
I had this same issue with the same chip, after trying many many things I ended up in a situation where 3dmark simply wouldn't open, only solution was a clean os install.
