Problem with 4 monito setup
10 Sep 2015
Ok
I have 2 x MSI GT610's running 4 monitors using the cards 2 dvi out and 2 vga outs into the monitors vga and dvi inputs.and it works fine.
If I try to use the 2 dvi outs and the 2 hdmi outs from the card in to the monitors using hdmi to dvi cables it doesn't work. Win10 detects the monitors just fine but the screens are blank.
Any ideas? Would there be any reason you can't use the dvi and hdmi outputs at the same time?
