problem with 5870 Flash
24 Oct 2008
South London
I have flashed it succesfully but I can't install any drivers, it will keep coming back as failed.
However I was able to install the latest set of Xtreme-G Drivers but theres no CCC so when the card was getting full load the fans wasn't running properly.
GPU-Z reports it as an Asus card, it was a Sapphire card before.
If I go to device manager I get something I have never seen before.
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
However its just weird that the Xtreme-G drivers worked and that message in device manager went away and reports working normally. Can't leave it like this though since theres no CCC or fan control.
What bios have you used? There could be a problem with the bios, I had this once with my 4850s, where the drivers wouldn't install with a bios I'd flashed. I flashed it back to the stock bios and they installed fine.
Just checked GPU-Z
Bios version is reported as 012.011.000.006.034494
Sub Vendor: Asus(1043)
Also just tried it was an MSI 5870 flash and its doing the exact same thing couldn't then install the Xtreme-G Drivers now back to the Asus flash and I can't even now install the Xtreme-G Drivers again, tried driver sweeping and fresh install.
Am i doomed to going back to my normal bios with locked performance ;; :(
one thing I noticed when finishing in dos with the flash its changing my hardware ID's etc, then says to restart to install new hardware, at that point I am just hitting the reset button and pulling out flash disc. Am I doing that right?
I take it you flashed to the Asus bios for overclocking ?
Running without CCC shouldn't cause any problems afaik, unless you need access to colour settings, brightness, etc... Afterburner allows you to set a custom fan profile, so its preferable to CCC's fan control anyway.
If you're concerned about it though, do what kyle suggests and flash it back ?
This, flash it back and use Afterburner for "unofficial overclocking".
