Problem with ati 5870 win 7 64bit
18 Nov 2009
Hey guys
I have bought a couple of week ago a Titan goliath with a vaporx 5870 form OCUK, I use 2 24" dell (1 U2410 and 1 2407wfp) monitor.
The probelm is that 1 of the 2 monitor (not always the same and not only the secondary of the extended monitor configuration) have the immagine that is flickering but it seems that the problem apper only if I run a game in the other screen. For example 1 min ago I had WOW open on my right LCD and the left was flickering. Now I have closed WOW and the probelm is gone. I tryed with clean and reinstall driver, now i'm using 9.12 beta but i have tried 9.11 and 9.10 and the probelm was the same.
I really can't understand if is a hardware problem of the VaporX or a driver, win 64 bit issues. Any of you has any advice??
Regards from Italy
Karaboca
Overclocking the card causes this fault. Try running the card on stock speeds and see if the issue goes away.
If it does then you need to wait for the 9.12 drivers to see if this is fixed.
Same happens with me if I overclock my 5850 as I have a Cintiq plugged into the 2nd port of my card. Running at stock as mentioned fixes it here, so fingers crossed the new drivers will address this.
Matt.
download gpu clock tool, google it, a site called techreport or something similar is a safe place to get it.
When you boot up windows, open up the tool and set your 3d clocks in it, just the standard clocks your cards are capable of. The issue is caused by some odd behaviour of the powerplay tech which reduces the speed. Gpu clock tool overrides the powerplay settings and forces the card to use whatever clock you set it to all the time. Its not perfect idle speeds will be higher and use a bit more power. I'm not entirely sure, you can probably set a lower speed and voltage but it might take some playing to find something low voltage/speed and stable. But you'd also have to remember to set the 3d speeds back manually before playing a game.
Hopefully powerplay will be refined in the next couple driver sets so we get more stable powerplay function. Apparently the flickering is a timing issue, I assume because the basic idea of a basic ramdac that could run 2 monitors that we've used for well over a decade, was changed to use 3 screens per card. So now theres some timing issues when dropping speeds, it should be easy to fix.
I tryed gpu clock tool but seems that it have some problem with win 7 64 bit and gave me some strange error.
I have also modified the "profile" file in ATi folder changing by hand the value of clock and memory as suggested in a another forum, but had some artifact and monitor flash.
I really hope next driver will fix it.
