Problem with bluetooth between my ipod touch and my phone
6 Oct 2004
Behind you!
I recently bought a new phone and an ipod touch. The two things where meant to compliment each other and for this I was relying on bluetooth as a means of transmission. Unfortunately My phone is able to to detect my ipod, but it won't establish a connection with it. The ipod can't even detect my phone at all. I have switched bluetooth on on both devices and made them always visible, but no luck. I have the following:
Samsung Genio Touch
iPod Touch 2G 32GB
I realise it's a rather specific set of circumstances, but maybe someone on here can point me in the right direction? I'd appreciate it!
(Wasn't 100% sure if this is the right forum to post this in, but it seemed the most appropriate.)
What are you trying to use the connection for? The iPod Touch has a very limited set of Bluetooth profiles so there is no file transfer. As far as I'm aware it only supports:
A2DP Source (Stereo Audio Transmission)
Partial AVCRP (Audio/Video Remote Control Profile) - to control the iPod playback (only play/pause is supported)
HSP (Headset Profile) - To use a Bluetooth headset
HFP (Hands Free Profile) - To answer and make calls via a headset
Sigh, that's irritating. Despite quite a lot of research into it that's a missing feature I didn't pick up on.
I just wanted to be able to transfer photos/mp3s or whatever between the two things. There are other ways of doing it, but it'll be more complicated. Oh well, thanks for the reply :)
hi
did you find any futher info out
i have the ipod touch 2G. i've enabled bluetooth but it finds no devices when i search. likewise when i use my phone to search for new devices (windows mobile) it finds nothing.
does the ipod only pick up other ipods/iphones?
bit useless if it does.
ta
