Problem with buttons on Silverstone FT02
13 Jan 2012
London
Hi Guys
I have problem with power and reset buttons on Silverstone FT02 case.
Do you know where i can buy replacement buttons?
I buy this case in February 2012.
Many thanks for your help
They are a bit slow, but they will get back to you and are very polite and helpful when they do.
I've had a look around and it seems that Silverstone will be the place to get new buttons from I'm afraid. You can get I/O upgrades for some cases, but I can't find buttons.
Unless you want to make new ones - what's the problem you're having?
Have you tried shorting the pins where the buttons plug into the motherboard to check they're OK? I had a weird reset problem many years ago where the system just wouldn't reset and it turned out it was the board was dodgy.
You can just put a screwdriver between the pins of the power or reset on the board to make the connection like a push switch would.
Problem resolved! I have receive new buttons even if my case is no longer under warranty :).
Many thanks
