Problem with EK 240
22 Mar 2014
So i have had this for about two weeks now. Booted up tonight and the fans were going crazy :confused:
Checked with core temp and it was recording around 90 on some cores!
Shutdown straight away and reset to default clocks just incase some voltage adjustment i had made in overclocking was in error. ( i've not changed it for some days now and its been stable during gaming etc)
Just about to reboot in bios when i hear a load of noise from the preadator and the temp shoots down. Airlock?
Not sure what i should do about it as its installed as per instructions. Does it need filling? i would have thought it would be perfect from factory?
Are you using any software though, Speedfan? Can you not set a custom fan curve up and see if that sorts it out?
