- 21 Feb 2012
- Mansfield, Notts
Ok problem with my first build, just put my 3570k into pc, and on my MOBO it shows the red DRAM light and wont post. It repeatedly turns itself on and off again every couple of seconds, however if I remove my RAM sticks it will stay on longer but still not post. I have tried swapping the sticks over, and just with one stick of RAM. Is there anything that I should be doing? Everything seems to have been put in properly. All parts from OCUK and nothing 2nd hand, only thing I am reusing is the optical drive, which was working last time I checked.
So is the RAM or something else?
Does the DRAM light flash if it is another problem other than RAM?
Specs:
i5 3570k
Asus P8Z68-V LX Intel Z68 (Socket 1155) DDR3 Motherboard
( https://www.overclockers.co.uk/showproduct.php?prodid=MB-483-AS )
Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Specs:
i5 3570k
