Problem with formatting a USB Flash Drive [Toshiba 64GB].
BuZ
BuZ
26 Oct 2011
The Universe
Hello all,
I need a little bit of basic help with formatting a memory stick. I have tried it on 2 computers and numerous USB ports. I can't seem to get the flash drive to format. It says "Cannot format".
Thank you in advance!
Or to save you downloading software.
Open command prompt, type diskpart, then list disk. Look for a disk that matches your usb (i think only size is listed), select disk #, clean. You should now be able to reformat your flash stick to whichever format you wish. If this doesn't work then it's likely the memory has corrupted.
