Problem with GTX 580
31 Aug 2011
GTX 580 PNY 1.5GB
Intel i7 960 3.2ghz
Corsair TX650 PSU
6GB Corsair Ram
I just put it in and my score on 3d mark vantage was 23000, i expected to get more than this? is this a correct score for this card?
Also i just downloaded a programme called Techpowerup GPU-Z
Somehow it just doesnt seem right> Lots of the boxes say "Unknown" and memmory type sayd GDDR3?? i thought it was GDDR5?
http://imageshack.us/photo/my-images/855/image1jj.png/
http://imageshack.us/photo/my-images/11/image2ph.png/
Some help, advice, information would be appreciated, thanks
Why do you need to bump your thread after 15 minutes?
Try the latest version of GPU-Z here.
Google "GTX 580 3DMark Vantage" and you'll see plenty of scores around the same as yours.
Edit
I see your problem was so urgent you bumped the thread after 15 minutes and then haven't checked back for nearly 5 hours to look at the answers.
Have you tried doing a clean reinstall the drivers for it and checking your bios settings? Does the card have enough power and are the connections all clean and tight?
