Problem with GUI after/during login
6 Jan 2008
Hi there,
I'm having an issue with my Fedora setup since doing some updating to a program on there.
Basically now, when ever the system starts and I normally would be asked to login, that screen is now black with a spinning ball showing its constantly loading.
If I leave it, it will never move on from that point.
So I ran the following command from ssh login: Set runlevel to 3 in /etc/inittab
and then restarted the system to use startx. Upon using startx, the GUI loads fine. But if I set the run level back to 5, the GUI fails to load again.
Can anyone think of why this is occurring?
Thank you.
Have you checked /var/log/messages for anything relevant during the end of the boot process?
You can also press ctrl + alt + f3/4/5/6/7 for a shell, might be worth a go logging in as root, and type ps faux to get a list of processes to get an idea of what the system is doing, also check dmesg for any output relating to your problems.
check what is running at run level 5 and not at 3 which could be causing the issue
chkconfig --list
Guessing whatever you updated is trying to start at run level 5 and faceplanting itself but is not running when u startx in run level 3.
