Problem with HP DV6000
17 Mar 2011
Spain
Hi All
Looking for some help with what to try next with my laptop.
Saturday morning it was working fine and shutdown ok then Saturday evening I got nothing.
When switching on the LEDS come on, the DVD Drive kicks in and the HD LED flashes for just 1 second but then nothing and no display on the screen, completely blank.
I have tried the following:
Swapped HD
Checked memory and tried another stick from a working laptop
Did the power reset thing with battery removed
Removed CMOS battery
Checked fans are working
Connected to external monitor but still nothing
Now am lost. I had 3 OS on this system and never had a problem with any of them and laptop has never crashed or anything and never had an issue with overheating.
Appreciate any advice as this is a nice laptop and in perfect condition, when working
Cheers
sell is as faulty, buy a new laptop......
assuming you mean the lights stay on, if they flash and go it it might be the power socket....
That Nvidia chip of death sounds a likely cause. Seems like a lot of problems with the HP DV laptops and the graphics chip. Not exactly HP´s finest hour.
Found a few guides about trying to fix this by using a heatgun on the chip. As possibly knackered may give this a try, have nothing to lose and if it fails I guess i could always chuck the screen on Fleabay.
Well I found a great little guide on youtube where the guy used a small blowtorch on the chip. To my suprise after giving this a try everything started working but only for a day and then it went again so its basically kapput but decided to break it down and already the screen went to someone for €50
