Problem with memory and graphics card
26 Dec 2009
i bought the G-Skill 4GB (2x2GB) DDR3 1600MHz/PC3-12800 Ripjaw Memory Kit CL7(7-8-7-24) 1.65v
thing is when i CPUZ on it doesnt show it to be running with them timings.. it shows it to be running with 9-9-9-24 etc which is the slower stuff?
iv checked in the bios but it doesnt make much sense.. ill try get a picture if i can.. there both in the same coloured slot on my motherboard as thats what it says in the mobo instructions.. my motherboard is the ASUS M4A77TD PRO 770.
The other thing is my graphics card wont run dual screen with this monitor (22" SyncMaster Samsung) and my tele which is only a 19" but has a VGA connection for the PC
my graphics card is a Gigabyte HD 5750 1GB GDDR5 it has dual DVI so i have to use the adapter for my TV. my 22" works fine in both ports on the card using DVI when i plug the adpater in with my 19" screen it detects something is connected but doesnt produce a signal so nothing comeso n the screen..
iv tried it with my laptop and i can get it run in dual boot with that but i dont need the adapter to do that.
you think its possible that i have a faulty adapter?
cheeers
