Recently built this PC
GByte GA-Z77-D3H Z77 MoBo
1TB SGATE ST1000DM003
Intel Core i5 3570K
8GB 2x4GB CML8GX3M2A1600C9 LP
120 GB Sandisk SSD (OS on this drive)
Zantec LED CPU Cooler
5 led case fans
500W Power
(No GPU)
Set up Pc, no problem, booted first time no problem, installed new Windows 7 Home Premium all no problem.
Build was for a friend, gave it to him, he saw that 100 windows updates needed to take place so left it running and went out.
came home to find the PC off, turn it on, all seems to power up but no signal to monitor via DVI or HDMI
again everything turns on, you hear the HDD make a noise but nothing on screen.
he tried later and it turned on but windows needed to be repaired, this wouldnt repair.
I got it back today, it turned on fine, put windows disc in and formatted SSD and reinstalled windows.
Everything was fine until windows updates which made the PC shut down when finished.
Then I experienced the problem, PC turns on, all kicks in, fans etc but nothing on screen and no lights on my USB devices (mouse keyboard). I have since tried all possible RAM stick combinations the PC did turn on a couple of times and load up windows but once I shut down and turned on again, same problem....
it maybe works 1 out of 10 times, cant find a pattern to it.
I am typing this from the PC at the moment, chances are when I shut it down it wont turn on correctly again??
Any advice is welcome, I hope I have provided enough information.
Alex
Intel Core i5 3570K
5 led case fans
500W Power
(No GPU)
Alex
