I'm really hoping I might be able to pick your collective brains here!
So my new processor arrived today, an AMD K6-266 AFR (regular Socket 7)
However after installing it, all I'm getting is a black screen and "no signal" on the monitor. Swapping the old CPU back works perfectly, so I'm not sure what the problem could be. The seller assured me he had tested the CPU before shipping and it was perfect.
There are no real markings on my motherboard to identify it, other than a few numbers -
It says E139761 along the top edge, and a white socket with: 3M1X2YY 9709. A Google search didn't turn up much meaningful info.
It's a Gateway 2000 system with an AMIBIOS version of 1.00.07.DQ0T UAV
Could it be that the motherboard/BIOS is not compatible with AMD chips? The working processor that I removed was a Pentium 200MMX, and as I say this works fine if I swap it back in.
Any advice you can throw my way would be really appreciated!
