Problem with new router
16 Dec 2009
I bought a second hand router a while back that was on sky but had been flashed so worked on any broadband, Its the netgear dg834gt. It says the modem is connected at what ever speed im supposed to be paying for but when i click test connection or try use the internet I cant get on. What do i need to do to get on the internet? all the settings I need from 02 are already entered.
If you reset router does it allow you online for a time then play up?
Are you connected with cable or wireless to the router?
What firmware version are you using? Latest Netgear release is 1.03.22
I havent been able to get onto the internet at all, I think i have all the settings on right, I even rang up 02 but they only read whats on their screen.
Im wired to the router.
I have tried that firmware, even older versions. I tried flashing the flash like people say to free the router up.
Ive never done this before so not sure what signs to look out for, I just cant access internet on it. Wish the 02 router was any good.
In the netgear web manager (192.168.0.1) what does it report for Maintenance > Router Status > Connection Status? Connected, Success and Success?
I've got a DG834PN, so I assume it's much the same.
shouldnt have any issue as i am using a sky branded gt on talktalk LLU.
Any custom route rules on your pc etc?
what do you get when you go to start>run>cmd then type ipconfig.
It says connected on that bit but i cant access the internet, im just wondering if the router is still blocked to only sky.
Ok but for the modem to appear to be talking to the 02 servers, the connection status window should say:
Connecting to server: Connected
Negotiation: Success
Authentication: Success
Double-check all three are healthy.
Ive got a feeling mine doesnt come up with that, i know it says connected. all the 02 settings should be set but might need to email them so i dont get talking to a muppet.
the link doesnt work? is that the one with router settings? If it is ive tried both differnt ones.
This is what my router says.
IP Address ---
Subnet Mask ---
Default Gateway ---
DHCP Server ---
DNS Server ---
Lease Obtained ---
Lease Expires ---
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN DHCP Client 39 0 0 0 0 00:00:00
LAN 10M/100M 474 430 0 420 94 00:09:52
WLAN 11M/54M 76 0 0 24 0 00:09:50
ADSL Link Downstream Upstream
Connection Speed 7776 kbps 448 kbps
Line Attenuation 7.0 db 5.5 db
Noise Margin 12.3 db 22.0 db
Testing Internet Connection
This Page will Automatically Display the NETGEAR Website if a Successful Internet Connection is Detected.
I Hate Routers!!!
Yup, sorry link no worky!
From your settings it does look like the router is talking to the exchange server but not signing into the 02 servers - not authenticating.
I guess you're on 8mbit Max? If so, you just need the second lot of settings - Home Access Settings - and in the Basic Settings it would need to be PPPoA.
