Problem with OC settings
24 Apr 2012
Hi, I have a problem with my OC settings - the Multiplier that I choose in the BIOS is not being applied when Windows boots. I select multi of 44, yet CPU-Z tells me that the multi is 45. Because the vCore is being applied correctly I keep getting BSODs on login due to 1.24v not being anywhere near enough to satisfy 4500MHz on my chip.
I am on the latest BIOS for my board (1805) and have tried loading other OC profiles and 'Optimised Defaults' as well as only changing settings from a cold-boot. This problem started with BIOS version 1708
Does anybody know what might be causing this issue and how to fix it?
The only thing I can think of is re-flashing the BIOS.
