- 19 Dec 2006
- Saudi Arabia né Donegal
Hello all,
I'm rather embarrassed to ask this but I require some help with my overclock. Essentially the settings are failing to stick no matter what sort of clock I set. In the past I've been able to run my cpu at approximately 3.1GHz but now it will refuse to run at anything other than stock (1.8GHz). I've tried the settings that have previously worked for me and I've tried applying a small clock increase of just 50MHz along with everything in between but with no joy, it keeps reverting to stock.
System Specs:
Motherboad: Gigabyte 965P-DS3P Rev 3.3
CPU: Intel e6320
RAM: 4GB OCZ PC6400 DDR2 800MHz
OS: Win 7 64bt
This machine used to be perfectly stable 24/7 with the previous clock but I'm not sure when it stopped working, or why. I haven't made any hardware changes recently bar installing a new hard-drive though I doubt that would have had an effect.
I'd really appreciate any help you guys and gals can offer on this,
Antar.
System Specs:
CPU: Intel e6320
OS: Win 7 64bt
Antar.
