Problem with Prolimatech Megahalems
8 Oct 2009
I was just building my rig...
I have a gigabyte Ud5 mobo, a prolimatech megahalems and 6gb corsair DOMINATOR.
The Cpu cooler is blocking 2 slots not 1... I knew it blocked 1 slot but not 2. The second slot is not completely blocked though.
I managed to fit the ram in the second "blocked" slot, however because the dominator have large heat spreaders, it is a bit bent and it's touching the prolimatech cooler.
Is this ok? Or will something break or something?
Also forgot to say... The prolimatech is installed facing upwards... i mean the fan is on the bottom and pushing air upwards.
Should I change it to sideways, i.e. rotate the cpu cooler by 90 degrees and make the fan push the air towards the rear instead of up?
