Problem with router syncing
  • Thread starter Thread starter Faz
  • Start date Start date
Faz
Faz
18 Oct 2002
I'm trying to set up a router for a friend. He has broadband through BT, which works fine with the intel supplied usb modem, however when I connected a new netgear DG834G router the light that shows the connection status flashes orange.
The router is accessible through ie and the network side of things seems ok, it just won't sync.
I Tried the router on my line at home and it syncs there.
This has all come about as he's had his laptop replaced with one that's running vista and I cannot find any vista drivers for the intel modem.
Is it likely to be a problem with his line that stops the router syncing, or are there any settings within the router to adjust
Cheers
Faz
Since you managed to configure the router on your connection at home clearly the router is working so it has to be down to a configuraton issue when you are at your mates.
Does this router have any logs? Or what does it say when you try to manually connect to through the webinterface?
Most likely your problem will be with the username and password not being correct.
I don't get as far as user name and password, the light should go green to confirm it recognises there is a phone line connected to it.
