problem with smartdoctor 8800gts
3 Jun 2006
i have recently upgraded from XP to vista 32....
i have installed the latest drivers and latest version of smartdoctor.... however when i open smartdoctor i get the following message
Can't Open Kernel Mode Driver Service
and the program wont start.... the same thing happens when i try to run ATItool...
could really do with getting these to work.... any suggestions??
From what i recall smartdoctor is some software Asus supply with their cards and motherboards , or am i getting confused ?
If its program i'm thinking of ditch it , it used to be trouble last time i used it a couple of years ago and from what you've said doesn't seem to have improved :p
Try rivatuner , that seems to be the most recommended at the moment.
not sure if atitool works in vista as it says on the homepage
ATITool will only work on Windows 2000/XP/2003 (64 bit versions are supported)
Its probably the same problem as smartdoctor , it tries to install services which Vista won't allow with its new security
