Problem with Vista and my Gigabyte DS4
29 Oct 2002
stoke-on-trent
Can't get my sound to work? The disc that came with the board will not autostart like in XP? I have install the the sound drivers still no luck, any help would be appriciated. The disc says ver 1.0, I take it this means the mobo is version one can't see a label anywhere on the board given version number?
I am also having trouble with copying files they seem to take ages, and installing software when you have to unpack the software is a joke. Is there any fix for the copying problem?
You need to explain a little more, what do you mean by, "It still not work?"
What's not working? What are you doing? What (if any) error messages are you getting?
Ok sorry I have been fighting Vista all day. I can get my rear sockets to work but not the ones on the front of my case? They worked ok under XP with no problems, I have not changed anything.
