Problem with VP930B buttons
12 Aug 2005
Singapore
Hey guys, just discovered that the Buttons on my VP930B are not working, the 1,2 and up down buttons..
When i press on them nothing happen..
Are they faulty or could it be some software installed on my system that is disabling it?
Thanks..
Odd ... I'm not sure what could be the problem there. Are they definitely not working?
I'm also not sure about any software that would disable them either.
ya, there's no response when i press on them..
but cant be that all 4 buttons spoil at the same time? the on off button is working..
Hmm the resolution popup, keep coming out when i launch applications taht are no running at 1280x1024, i've disabled it before, but its back again, and now my buttons are spoilt, may i know is there any software method to remove that?
Thanks..
