Problem?
Permabanned
22 Jul 2006
Ive got the - Asus M2N32-SLi-DLX nForce 590 SLi (Socket AM2) PCI-Express DDR2 Motherboard (MB-142-AS) installed today along with my X2 3800 and GSkill LA 5300 2GB RAM.
I think there is a problem with the board, I have had loads of trouble since I switched it on, I cant even get a picture on the screen now :(
Every time I overclocked it, or adjusted the hardware, I had to reset the CMOS.
Its a real pain, anyone have any ideas?
Cheers,
Are your RAM settings correct? It sounds like it could be RAM related? Perhaps it's just worth checking those details compared to what the manufacturers quote?
Also, what PSU are you running? low power can cause all sorts of crazy-ness.
Cheers,
James
PSU - Enermax Liberty 620W, I would have thought the RAM would be ok, I got into windows ok for a while, unless I tried to OC it and it fooked up. :(
It is sounding like a suspicious 'board. Are all the voltage rails healthy and the temps okay?
Is there a BIOS update for the motherboard (if you can get it stable enough to receive it).
Cheers,
James
