Problem
10 Nov 2006
I've just finished cleaning out my computer, tidying up cables and re-seating heatsink etc. My system wasn't clocked before but i've overclocked before on an identical system so i have a rough idea of what i'm doing.
It's currently running at 2.8GHz on stock volts but i'm having a few problems when making changes. I can't seem to reset my computer at all, whether it be in windows or after i make changes in the BIOS. The system will post ok but the monitor doesn't receive a signal although the computer itself sounds like it's booting into windows as normal.
Temps are ok at 36 idle and 44ish under load and usually the only way of resolving it is to switch the computer off, leave it a few moments and turn it back on. Any ideas what's causing this?
Spec: 6300, DS3, 2GB Geil, X1900XT.
Thanks.
Shot in the dark here, have you locked your PCI frequency? Personally I use 101, I've seen other people go up to 110 I think
Naud
I haven't touched it but i spose giving it a whirl won't hurt. Gonna try another reboot now as i've made a few other changes since my last post.
