Problem
11 Nov 2007
So for the past few days I sety my new build up an its working almost perfectly but one problem...
Everytime I turn it off of a night to go to bed, when I wake up the next day it wont turn on becaudse the BIOS has resetted (Voltages has changed etc) so to fix this I take one slot of ram out an put it back in an it'll turn on fine and then I change the BIOS back to what it was....
Why is it my BIOS+CMOS Keeps resetting? Anyway to fix this would be great thanks!
Also would it matter what slots I have my RAM in? I have 2GBx2 an one in a blue slot and the other in a blue slot...
Can anyone tell me if my 3DMark06 score is good for my set-up too?
My score was as follows...
3DMark Score 11654 3DMarks
SM 2.0 Score 4499 Marks
SM 3.0 Score 5299 Marks
CPU Score 3656 Marks
and my set-up is
Abit-IP35 Pro Motherboard
OCZ 4GB RAM
Q6600 @ 2.4
8800GTS 512...
Nothing has been overclocked atall....
Sorry for so many questions bu thanks again for any infp/help:)
Bump again
Just incase im missing anything...to save the BIOS i should just exit it right? ofcourse press "y" when it prompts me to exit with the changes?
or is it more to it to save it?
Please help :)
Check the CMOS battery with a multimeter/tester, should be registering about 3V, if not then that's your problem :)
that's a problem I've encontered a number of times, they are only pennies to replace and always worth doing, I've even seen them be below voltage on a new board.
doggo
