problem...
21 Jun 2008
hi, i recently bought a new pre-built from OCUK, ive already had to send it back because it wasn't overclocked to 3.0ghz and there was a hardware failure or something...
ok now the real problem :(
ive been playing this really old skool game called total annihilation, its like 10 years old...ive had this problem with this pc once before (before i sent it off to ocuk) but i just got it again.i was happily playing a game with someone over the net and suddenly lots of lines appear on the screen, the thing is all pixelated and on the right hand side of the screen its just black so i have no idea wtf has happened, maybe you guys could help.
my pc:
http://www.overclockers.co.uk/showp...6600 2.40GHz @ 3.00GHz+ Quad Core DDR2 System
Code:
Problem signature:
  Problem Event Name:	BlueScreen
  OS Version:	6.0.6001.2.1.0.768.3
  Locale ID:	2057
Additional information about the problem:
  BCCode:	124
  BCP1:	0000000000000000
  BCP2:	FFFFFA8007A45030
  BCP3:	00000000F2000040
  BCP4:	0000000000000800
  OS Version:	6_0_6001
  Service Pack:	1_0
  Product:	768_1
Files that help describe the problem:
  C:\Windows\Minidump\Mini071808-01.dmp
  C:\Users\Rob\AppData\Local\Temp\WER-55281-0.sysdata.xml
  C:\Users\Rob\AppData\Local\Temp\WERD987.tmp.version.txt
Read our privacy statement:
  http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
i cant find the last 2 documents ^^^ but i can find the mini071808-01.dmp file but i cant open it...any ideas?
thanks!!!!
Can you find the last 2 files' folders? or is it just the files missing, because the AppData folder is usually hidden if that's what you can't find. (show hidden files etc in the folder options and look again.)
Bit of a long shot but have you tried messing about with the compatibility options in xp (the ones you get from the propertied of the program shortcut)
TA is an old game. Not a lot of old games work well with Vista and I suspect this may be your issue. Do a search on the net and there's a few articles about online TA games with compatability problem between users with XP and Vista.
