Problems after changing case
1 Dec 2008
Ok this will sound strange, i recentely swapped all my components over into my new case, and i've had several problems since, sometimes upon pressing the power button, the PC attempts to power up, and immediately turns off
another one from the small LCD screen on the back of the motherboard was CPU init, CPU initialization, and the other was Detect Dram,
Another problem is that the PC turned off after connecting a webcam
Any ideas?
I have this problem where by when I turn on the PC it powers up, then turns off then powers up again and boots fine. Although ive never found out why sadly.
Could it be shorting against the case or any of the standoffs? I have a really annoying issue where my machine would randomly reboot. After weeks of trying to find it I realised I had a standoff in the wrong place and it was shorting against the board. I moved it and it's rock solid now :)
Are you by any chance turning the system off at the mains, this dual boot is a common issue on modern motherboards, if power has been removed from the system, upon turning it back on, it boots first to check settings, switches off again and then proceeds to boot as normal, if you switch the machine off via the start/shutdown in windows and leave it plugged in at the mains itll boot ok on the first attempt. Its basically performing a check to make sure all is ok.
No not turning it off at mains
Aaaaaaaaaaaaaaaa, I turn mine off at the mains at night and have been wondering why it does that for months.....thanks for that ;)
