Problems after Vista Update
8 Jul 2007
Reading
After installing the latest vista updates and restarting, my mouse icon has vanished.
Only way to get it back is by doing a system restore. Does anyone know why or has had the same problem and knows a fix.
Is it a USB mouse? Sometimes my Razer Lachesis is lost (i.e. the mouse pointer disappears or won't move). I just unplug and plug back in and voila! It works. :) Doesn't happen often, but sometimes.
Mine too, its not a razer, its a kingston track ball, but it did it in XP too, i found using a USB>PS2 adapter solved it
Yep it is a USB mouse, but I had to reinstall the driver to get the pointer back.
It's a bugger trying to navigate around with just the keyboard, especially when it came to ticking the user agreement box when downloading the driver.
