Hello all,
Have been wrestling with my new build all day, finally started to install windows and now a real problem. The computer was restarting to continue the install when it all went wrong.
When I press the power button one of the case fans start spinning and a harddrive whirrs but that's it. The CPU fan, other case fan and graphics card don't power up and as a result won't post. This happened a couple of times earlier on but I put it down as some electrical gremlins as the computer soon fired into life. But now nothing. The one case fan that does work I suspect does so because it's connected directly to the power supply rather than the motherboard, if it's plugged into the mobo it doesn't power up either.
I suspect it's a motherboard or psu problem, all power plugs are firmly connected.
Spec:
Intel i5 2500k
Gigabyte ga-z68ap-d3
8gb kingston ram
Crucial m4 ssd
Seasonic M12 600w
Does anyone have any good ideas?
Spec:
Intel i5 2500k
8gb kingston ram
Crucial m4 ssd
Seasonic M12 600w
