Problems enabling and disabling Crossfire?
it crashed again and now its come back on, and crossfire is enabled, no crashes.
i dont dare disable it again tho, so until there is a fix i guess im gna have to hook up my tv to my laptop or sumet??
when you get a chance run 3dmark 2006 .....that should let you no if yah running in crossfire...you should get a higher score....what score did you get using single card ..
yeah i get about the same on single card but when using crossfire it goes to 13.000..nothing is overclocked for me though
if you go to device manager, under sound, video and game controllers, the ati t200 avstreamer or something is missing, but it wont install
i think that is the problem, think that is the shader drivers
ive removed the drivers and now i installed from the cd and are going up each driver revision, at 7.5 now still no luck
ok so installed from cd upto 7.7 and 3dmark score is
14824
so it seems to be working now
i still need to be able to swap between crossfire and dual screen mode tho but im not gna risk it for now! ill just hook my laptop up to the TV.
