Problems formatting (Vista 64 Bit)
16 May 2009
Hi guys - I wonder if anyone could help me?
I'm trying to format my Windows Vista Basic (64 bit), I do the ususal thing of pressing key to boot from CD on start up...
I then get the windows is loading (black and white bar at the bottom)...
Then it comes to a blank installation screen which looks like the below image;
The mouse cursor appears and I wait thinking the installation menu will appear, but nothing happens - it just stays on this blank screen along with my mouse cursor...
Does anyone know why this is happening? :confused:
Cheers eXor, I went downstairs for about 5/10 minutes and came back up and the menu screen was up!
I guess my impatience is to blame, although you'd think they would have some sort of loading symbol or something to tell you its loading the installation wizard...
Anyway, as I felt such a twit I came back on here to say thank you before formatting, will now go and format :)
cheers :)
