Problems Getting Xbox Live to Work
30 Jan 2006
Basically, i have a wireless router downstairs, which connects to my computer which is upstairs- and im hoping to add a ethernet cable from mine to the xbox 360.
However it doesnt seem to detect it, the lan just says limited or no connectivity, unless i manually give it an ip- it can share connection but it then cuts off my computers wireless :S
Any Ideas How i can sort this?
I think you need to bridge the connections or somethign in netwrok connections i read in a thread the other day? maybe this will help. i will try to find the post now.
Sorry to bring this thread up again but ive run into another problem -
Playing GoW online was perfectly fine until a few days ago - now it seems to constantly lag to that point that it becomes unplayable- i havent changed any settings and the only thing ive done is downloaded some xbox live demos. Any ideas what could be causing it?
Are you on your own connection? Is your internet speed fine? Tried any other online games on your PC? It might be your wireless signal is getting some interference from somewhere.
