Give up and send the Ram to me?
Only thing I can suggest is try 1444Mhz / 1300 mhz (nearest possible) and then remove XMP profile (I assume that is what you're using). Then stick the timings to "Auto" and see what happens.
And yeah, don't go above 1.65v for the RAM, not worth the risk to the controller. You changed your QPI/DRAM voltage?
I got this very same RAM in the post today as an rma replacement for my 1600 OCz... I'm enjoying it a lot!
