Problems Problems and Problems...
5 Jun 2005
Hi guys,
Just bought a new system, wish I didn't now... all I have had is problems, now its to the point of throwing the whole £1500 in the bin cos getting a massive headache over this.
First, had major problems with hdds. Was getting a weird noise coming from the hdds, a clicking noise. Its known to be a problem called the 'click of death' and took 12 hours to format and install windows. I'm sending them back to the place I've bought them from, hopefully get them replaced.
Secondly, once everything has been installed and I was getting a major problem with temp. Started playing a game of css with everything at max. The game looks lovely, then all of the sudden the comp started to freeze every 5 mins for 2-5 secs. Even when I left the game, I was still experiencing this problem in desktop until i restarted my system.
Temp:
GPU - 70-80
CPU - 45
System - 50
As I experienced this problem, I decided to uninstalled both mb/gfx drivers and install the latest available (was using drivers that came with the mb/gfx) and hopefully sort the problem out.
After restart, I was unable to use both keyboard and mice, and wasn't able to go no further than the windows login screen. This went on for a hour and in the end, had enough and thought lets format and start again.
When I put the windows disc in the drive, and tried loading the disc, the computer couldn't find the disc and when the drive wasn't reading the disc properly, and unable to locate certain files, it forced windows setup to crash/reboot.
Now, computer is useless... friends advised me that flash the bios and hopefully get me back to normal and start again.
Is this a hardware prob or something wrong with the bios?
I have done a memory check with the ram and seems fine but the mystery is the unable use of keyboard and mice, how come this wasn't working as I only uninstalled the gfx drivers, nothing more...
Hope someone can help, if not... comp out window!
Intel wolfdale 3.16
8800GTX
4GB ram
EVGA 780i mb
