I had Ati tray tools working perfectly with 2 different driver versions and then I started having problems when starting windows. On start up Ati Tool would as normal load up first and then as CCC attempted to load my monitor would go black - signal loss. This problem got worse, to point when it happened every time I booted Windows. When I uninstalled Ati Tool CCC had no problems loading.
In an attempt to rectify the problem I uninstalled Ati drivers with Driver Cleaner and reinstalled the latest Ati drivers and Ati Tool following the same procedure I used for the previous successful installation. Windows loaded no problems and disabled the Ati services in Windows (Ati polling) and overclocked, set voltages and fan speeds via Ati Tool. I ran 3dMark 05 with no issues but as soon as I tried to play a game my clocks would be reset to the very low 2d settings.
I uninstalled Ati Tool and then installed Ati Tray Tools so as to control my fan speeds. I overclocked via CCC but when I play games my 3d overclock is reset to the low 2D settings.
I am confused as to why a once stable installation with Ati Tool gradually became unstable. The only thing I can think of is perhaps its something to do with my Tagan 480W power supply becoming less stable? Maybe not as I am able to successfully overclock to 590/800 using Ati's CCC Overdrive. The main reason I want use a third party utility is to control my fan speed as I am wary of the low default speeds and the high temps when overclocking.
Would using an Artic Cooling Accelero X2 cooler sort out the temps and would I be able to connect it directly to the PSU so as to have it running at 100%.
Anybody have any ideas as to why I am unable to use Ati Tool.
