Problems visiting sites (but not other services (eg irc, https)
11 Mar 2009
scotland
hi,
having a bit of a weird problem, on two computers. I've fixed it on one (vista) by using the system restore, i think its a recent windows update that caused the problems. basically, one of two things happens
either 1) sites (ie, on port 80) will load for a while, then stop working
or 2) sites won't work at all
but in both cases i can ping (both domains & ip's, local and on internet), and can connect to irc, and https:// works (which i believe is a diff port than standard http)
ive tried disabling firewalls (i only use zone alarm and router firewall, but router hasn't been updated for ages (And is latest version)
anyone got any ideas?
thanks
on 2 computers though?
my vista machine (the other is xp) is working now (same zone alarm version) just with a system restore from a few days ago
there are reports that zone alarm doesn't detect windows updates properly and starts blocking network traffic instead
