just got 2 275 gtx installed them in my pc and they work in sli ran a few benchmarks and the screen was slightly flashing yellow and blue then it crash i rebooted
then windows areo would not work and lookied in device manager and it said that my 1st 275 had a code 12 inserficient resorces to run and the other said code 43 which said windows has stoped this device from working
so i reinstalled the nvidia drivers and there is only one now in device manager and no sli option ?? so got the old beta windows 7 drivers and they dont work just brings up an error
update:just tryed each card on its own in each slot and they work fine getting about 54.1to 54.3 fps average but when i put both in work fine its only when i put sli on and it goes pete tong and i get the same fps and the screen flashes slightly restarted it and only one card is showing again
any help would be most thankful
reformatted my computer put the latest windows 7 on it and still the same problem
when ever i do a bench loada game or it loads any sort of 3d app it starts flashin a slight yellow-blue tint on the picture and iam seeing no benifit in sli btw this only happens with sli ON..... if i disable sli it works fine
